Repair information for standalone freezers.
Freezer is still running
We have an upright Frigidaire Freezer (model LFFH17F7HWH) that keeps running. It freezes nicely. We have ran through everything we were told and replaced the control panel, door gasket, thermostat control and defrost heater, the thermistor, the run capacitor and the control compressor regulator. Still running. Temp shows 17-25 (fluctuates when we open the door) on control panel yet inside is nice and cold and everything is frozen like it should be.
11 Comments
Would an evaporator fan keep running and make the temp vary like that? If you noticed my question, we changed all the parts we could think of but not this part. It’s running all the time.
by
Hi @wendebruns ,
Do you get an alarm when the temp is >23 deg F? p.5 of the manual
Perhaps the temp is too warm and that is why the evaporator fan is running all the time.
Does the fan stop when you open the freezer door?
Place an appropriate thermometer in the freezer to see if it displays the same temp as the control panel.
Interesting that 23 deg F is deemed cold enough for the freezer (according to the manual). Most household refrigerators and freezers have 0 deg F (-18 deg C) as the temp required for the freezer.
Have you proved that the evaporator fan "blades" are actually turning and it is just not the fan motor spinning around?
by
Last time I had that panel off, the evaporator fan was turning. We did get an alarm last night from the high temp. But once we opened the door, it went off. The inside temp shows 12 degrees. Everything is frozen. Yet the new control panel on the door reads 26 and high temp. So frustrating. Thinking maybe I will try and change out the evaporator fan motor.
by
Hi @wendebruns ,
If I understand you correctly, the freezer temp was 12 yet the panel was showing 26
Given that you've replaced the thermistor (do you mean the freezer temperature sensor?) and the control panel, I'm wondering if there is a resistive connection between the sensor and the control panel.
It may be that the sensor is sending the correct resistance for the temperature but it is not reaching the control board as the same value due to a faulty connection perhaps and the control panel thinks that it is still too warm and keeps everything on
Can you use an Ohmmeter to measure the resistance between the sensor connector and the control panel.
Not sure if the sensor circuit is a "series" circuit where the sensor is in series with part of the control panel circuit or whether one wire is just connected to an Earth and the other then sends a resistive earth value to the control panel, which changes as the temp changes.
If measuring with an Ohmmeter disconnect the power to the freezer first.
by
Hi Jayeff, We did replace the temperature sensor (aka thermistor). The freezer quit running, temp showed -3 but high temp still shows. Now it’s running again, and temp reads 52. Still freezing inside and still 12 degrees. Can be so overwhelming but can’t afford a new freezer. This one is less than 4 years old and warranty ran out at 3 years. Go figure. Don’t think I will ever buy a Frigidaire again.
by
Show 6 more comments
Add a comment
1 Answer
Chosen Solution
Cause 1
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator coils and circulates it throughout the freezer. On most refrigerators, the fan motor will not run when the door is open. Make sure that the refrigerator door is closed and the door switch is activated. If the door switch is activated but the evaporator fan motor still won’t run, replace the evaporator fan motor.
Parts
Evaporator Fan Motor for your Frigidaire Freezer
RepairClinic Item #1483843
Evaporator (cooling coil) fan motor assembly with wire harness, 115 volts. *Per manufacturer screw holes in motor are not threaded from the factory, use old screws. See Related Items for self tapping screw. When the evaporator fan motor fails, it often generates a lot of noise in the freezer area.
Cause 2
Condenser Coils are Dirty
If the condenser coils are located within the freezer walls, the coils do not require cleaning. However, if the condenser coils can be readily accessed from behind or under the unit, you should clean them every 6-12 months. If the condenser coils are dirty, they won’t be able to dissipate heat effectively, greatly reducing the cooling capacity of the freezer. If the condenser coils are dirty or have not been cleaned in a while, clean them.
Cause 4
Sealed System Leak
If the freezer only freezes the top shelf, there may be a sealed system leak in one of the shelves. Sealed system repairs are usually cost-prohibitive. If the sealed system is leaking, you will probably need to replace the freezer.
Score 2
Add a comment
Add your answer
Wendell and Debbie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 39
All Time: 6,081
