Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Touch id on iPhone 6s won't work after transferring home button over?
Have a question, Had an iphone 6s where i replaced the screen and transferred over the original touch id, home button as I know you can't use a new one. I've done this many times, but this time the touch id won't work after put back together. It doesn't give any error at all. Just when you try to add new finger print, it acts like you don't have your finger on the home button... No errors. It just won't prompt you to scan your finger and can't get it to work. Any ideas?
2 Comments:
It’s either a bad home button or a bad home button cable by the sounds of it.
by
Thanks. I've replaced the screen twice in this phone, so maybe that's possible. So, there's no way to fix this cause this is still an only apple fix?? It's a backup phone, but I sure would like to get the touch id back. This sucks if apple it still the only one to fix this. Is it weird that there's no error?
by
Add a comment
@jason_b Well, the fact that your iPhone is giving you no errors is a red flag that either the home button or it's cable is damaged. I think you're going to have to make the sacrifice here and just buy a new home button assembly. If Touch ID still refuses to work after a new home button assembly then we have a bigger problem here, a board level issue.
iPhone 6s Home Button Assembly
iPhone 6s and 6s Plus Home Button Gasket
iPhone 6s Home Button Assembly Replacement
iPhone 6s Home Button Assembly Image
Product
$14.99
iPhone 6s and 6s Plus Home Button Gasket Image
Product
$5.99
2 Comments:
Thank you for the reply!!! But, I thought you can't use a new home button with touch id, and only way to get it to work is to have apple do it to record the ss to the home button? Is this not the case anymore?? We can do it ourselves and get it to work??
by
@jason_b the reason why I said "you're going to have to make the sacrifice here" is exactly that reason there. Nobody other than Apple can "pair" a new home button to an existing device and have Touch ID work. You don't have much of a choice here.
by
Add a comment
Check out this thread for some hints:
Touch ID not working after screen replacement
Add a comment
Add your answer
Jason will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 366
