Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Dropped laptop, display dark, backlight seems OK
I recently dropped the laptop, but there are no visible signs of damage.
The laptop boots up OK, works fine with an external monitor. Backlight seems fine too (little apple lits up, can change brightness, ...). However, I cannot see anything on the LCD screen. I also tried using a flashlight, but to no avail.
Do you have any suggestion what could be the problem?
Kind regards,
M.
Score 1
Add a comment
Chosen Solution
Try reseating the Display Data Cable. Was the unit open or closed on dropping?
Score 2
3 Comments:
Will try with the Display Data Cable. It was open on dropping.
by
Hows your screen alignment with the bottom case?
by
the screen and the bottom case are aligned just fine, no physical damage visible.
by
Add a comment
I followed 50+ steps for Display Data Cable guide and managed to fix the problem.
It seems that the cable wasn't properly seated in the first place. The fall finally took the cable out of the plug.
I have to say, it was a scary and exhausting experience with so many steps, screws and cables. I couldn't do it without such a great guide. Thanks guys.
Score 1
1 Comment:
Glad we could help solve your problem. You'll be much more confident if you ever have to go back in again. Actually after being on this site, I now do repairs of all kinds of things I would never have attempted before.
by
Add a comment
Add your answer
Max will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,850
