Repair and disassembly guides and support for the Digital SLR line of cameras by Canon, including the Eos series first introduced in 1987.
759 Questions View all
What is this part of the LCD screen called? (Canon 80D)
Hi everyone, I recently dropped my 80D on the grass, it had the LCD screen open, and luckily, it keeps working fine, but now doesn’t let me pull it out, as the “rotating” part broke (see photo).
As the screen itself keeps working perfectly well, I was hoping maybe I could get somewhere just this “mount” part, instead of changing the whole thing?
Couldn’t find this replacement part or at leas it’s name anywhere (neither could I find the whole screen kit with this base). Could anyone help?
Thank you very much in advance,
Alex
Add a comment
Most Helpful Answer
Looks like a compression fitting to me. Put the back into place and see if you can press it on.
Score 2
Add a comment
@geofocker that is simply called a hinge. Amazingly enough it does not appear to be readily available and when one can be found it is costly like on here
Score 2
1 Comment:
Thank you very much! It is, indeed, what I've been looking for. And yes, it seems a bit costly, but, will give it a try :)
by
Add a comment
Add your answer
Alex Krotkov will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 6
All Time: 400
