Screen repair not working
I just changed over to a new screen and nothing is coming on what should i do.
Sounds like you have blown the backlight.
Can you confirm that you disconnected the battey when fitting the screen?
If it's not backlight related you probably have a bad screen with no display.
Also check the flex cables on the screen that theyhave tape over any of the solder joints as this can short the screen out.
Yes I checked all the points and the battery was drained and disconnected during the process
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
2 Comments
Hello! Can you verify if its just the display not coming on, or is the entire phone not turning on? A good way to check is to make sure the phone has a charge, and attempt to turn it on. After waiting a minute or two, flip the ringer switch on the side, and if it vibrates, the phone is on.
by Jonathan Mechels
Yes i can verify it was working before with another screen and the screen cracked so I replaced it and the new screen does not work.
by Aiden Schafer
