kernal task threads psycho
What is this crap? Macbook pro 2015 13”
Your SMC chip has corrosion around it. You’ll need to remove the logic board as its on the other side. The area that needs cleaning is around the Orange marked chip:
To see more details on what the chips should look like review the MacBook Pro 13" Retina Display Early 2015 Teardown Steps 18 & 19.
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Retina Display Early 2015 Logic Board Replacement
Guide
Difficulty:
Moderate
Guide
Difficulty:
Moderate
20 minutes - 1 hour
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 94
2 Comments
Did you have a liquid spill at some point or sit the system down on a wet surface?
Did you just upgrade to Mojave?
If you can install TG Pro it high give us a clue on whats happening here. Post a snapshot of the main window Adding images to an existing question so we can see as well. You may need to stretch the bottom of the window so all of the sensors are visible.
by Dan
yes a liquid was there but now everythink clean...
by janisfjodorovs
