Left Shift button not working
Hi, I have problem with my left Shift button, It works only serval times, and then stops to work, after a while it works again, what it can be ?
I would pop the key cap off and see if there’s anything hiding under the key that could be preventing the key from being depressed and recognized by the logic board.
Next steps are
I recently repaired a 13” 2013 Macbook Air with the left-side shift, control, and option keys not working. I tried everything software related in addition to replacing the keyboard, and the keyboard -> trackpad ribbon. In the end the very last thing I did, which was to replace the trackpad, did the trick. Comparing the two trackpads I could clearly see that the connectors on the old trackpad had shoddy damaged pins, and the single pin that handled those three keys was damaged.
you could have something stuck in your keyboard if something is stuck you must replace your keyboard
If one of buttons are not working properly i need to change all keyboard ?? sounds dumb
or you could buy a new laptop
@stevejobs99 Don’t be rude.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 17
All Time: 7,030
