2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Works only with Power Adaptor attached though Battery is 100% .
MacBook Pro late 2007 will operate only with the power adaptor attached. The MacBook charges the Battery and shows 100% Charged as confirmed by the green lights on the battery. Removal of the adaptor at any time shuts down the computer completely.
Is there a fix for this comdition?
Score -1
1 Comment
Apple MacBook Pro "Core 2 Duo" 2.2 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA895LL - MacBookPro3,1 - A1226 - 2136
by
Add a comment
1 Answer
Chosen Solution
Well this is a puzzling question. Please download and run Coconut battery and give us the results. Here's the application: http://www.coconut-flavour.com/coconutba...
Score 2
4 Comments:
Coconut Battery reports Current charge: 4744 mAh
Maximum chare: 4927 mAh 96% as per battery monitor
Battery Capacity: Current Capacity 4927 mAh Design capacity: 5500mAh 89%
Details:
Mac model: MacBookPro 3.1
Age of your Mac 43 months
Battery Load cycles: 148
Battery temperature: 29.8 C
Battery Power Usage: 0.0 Watt
Is this what you (mayer) expected?
by
I'm not ignoring your response, I just don't have an answer. Would you give us the last three figures of your serial number so we know exactly which machine you have. My answer would be different if this was not the unibody model.
by
Last 3 numbers are X91.
by
I think your best bet would be to replace the battery connector. You seem to be getting power to it but not from it. Here's the part: [linked product missing or disabled: IF185-045]
by
Add a comment
Add your answer
Earl Stokes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 597
