MBP shutting down while high battery and only certain applications
Hey there!
My system has been shutting down consistently at around 70%-80%.
To add to that, once I plug in the MagSafe in for a little bit, and it lights up, I can unplug it and the system will continue working until the battery is gone.
I find that certain applications like games and such turn it off, but document applications don’t.
I’ve followed alongside lots of examples:
- Installed CoconutBattery, made sure the design capacity is well above 70%
- Resetted SMC, let the computer sit from 100% to 0% multiple times already, and it doesn’t shut down in this case when I run some scripts to drain the battery
- Ran Apple Hardware Diagnostics with the extended test and no errors came back
I was wondering if anybody has any solutions to this?
4 Comments
Can you post a snapshot of CoconutBattery both with the MagSafe plugged in and a second just on battery. Adding images to an existing question
by Dan
Hey Dan! Added!
by Ozma
Can you post the second one this time without the MagSafe connected.
by Dan
Hey there! Just posted!
by Ozma
