A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
176 Questions View all
My iMac lags (Freezes) a lot while using.
Hi Guys,
I am a repair technician and i have an iMac 2017 4K 21.5”.
It freezes a lot, like every-time i use it starts lagging, every 3-5 seconds it gets freeze for 1 second and mouse pointer gets freeze to one position and after a second it find it somewhere else.
I have replaced the Main Logic Board and also tried checking with another Known Good HDD, this is happening in recovery mode also and also when i try to do the internet recovery mode.
I am not really able to understand whats the problem.
Add a comment
1 Answer
Chosen Solution
You could have either a software level issue or your system is running in Safe mode as a sensor is telling SMC to go into this condition.
I would run the built-in diagnostics to see if anything shows up their. Reboot the system and hold the D key. If an error pops tell us what is said.
If this is a software issue you could have malware or you have some app consuming the processor threads. Open Activity Monitor and see what the top %CPU load is by clicking on that column.
Score 3
1 Comment:
Thanks Dan,
I even installed the latest OS and checked it was the same, i have checked with Known good HDD and Memory and still the issue was the same. But then i replaced the wifi card and issue is resolved now.
Anyways great Thanks for your answer.
by
Add a comment
Add your answer
Chetan Jain will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 250
