Moody (USA) Tri-point Driver For iPhone?
I have started converting all my regular use tools over to iFixIt “Moody” series “made in USA” the teal handle drivers.
I ordered a tri-point driver in this style to replace the current one I use in iPhones but it is not small enough. I ordered Y0 figuring Y1 would only be larger.
The current one I use is made by a knock-off foreign company called “BEST” and it says 0.6x25mm.
Referring to my iFixIt Manta driver kit it includes a “Y00” and “Y000” bit…I assume the “Y000” is the correct bit as when referring to a Phillips bit the “J000” is the best size for the majority of iPhones.
So, where do I find the USA made Y000 (or Y00) “Moody” driver!?
EDIT:
I just realized that iFixIt does not even sell their version of a molded handle Y000 tri-point screwdriver. I literally have to use their universal driver with a removable Y000 bit.
I see they have a plastic version of their precision bit driver which I may be more open to since its lighter therefor less of a chance I will personally over tighten a screw.
Still when working in tight spaces such as phones the bit driver is not narrow enough. For example if you are working on an iPhone without taking the screen off or removing the shield prior to screen removal you want a long narrow driver with a handle preferably taller than the screen…such as the Moody series drivers.
I contacted Moody directly, which is now owned by Central Tools. Waiting for an answer on a Y000 driver.
