PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Why does my controller not charge?
My controller will not charge. Sometimes if you get it just right it will charge for about 4 seconds and then turn back off. What should I do?
Add a comment
1 Answer
Most Helpful Answer
It may just be a battery issue. You can replace the battery with the part below. I also provided a guide on how to replace the battery.
DualShock 4 (CUH-ZCT1U) Battery Replacement
DualShock 4 (JDM-030 and Earlier) Controller Battery
Update (11/01/2018)
Here’s how you can replace your charge port, if necescery. Choose the right charge port for your model controller
DualShock 4 Charging Port Replacement
DualShock 4 Controller Charging Assembly (JDS-011)
DualShock 4 Controller Charging Assembly (JDS-001)
MicroUSB charging port assembly for the 2nd generation (JDS-011) PS4 DualShock 4 controller Image
Product
$8.99
MicroUSB charging port assembly for the 1st generation (JDS-001) PS4 DualShock 4 controller Image
Product
$5.99
Replace a battery compatible with a PlayStation 4 DualShock 4 controller models JDM-001, JDM-011, JDM-020, or JDM-030. Image
Product
$14.99
DualShock 4 Battery Image
Guide
Difficulty:
Moderate
15 - 30 minutes
DualShock 4 CHU-ZCT2U Charging Port Image
Guide
Difficulty:
Moderate
25 - 40 minutes
Score 2
2 Comments:
Hi @ajcooke01 ,
Not disagreeing with you but the OP states "Sometimes if you get it just right it will charge for about 4 seconds". I'm wondering if the "....get it just right..." relates to the USB cable connection and perhaps it may be a loose or damaged port.
Your thoughts? ;-)
by
I haven't had time to get around to fixing it but I am going to this weekend. That could be a possibility as well. If you have a link to a guide that might help me with that it would be much appreciated!
by
Add a comment
Add your answer
Wes Knutson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 197
