1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
How do I fix the flashing folder error?
I have opened the back to try and access the hard drive as I believe that something may be wrong with the connection between the hard drive and the CPU.
I’m now officially stuck, can’t find the hard drive in the back of the laptop. I can locate the drive chip, not quite sure if that has anything to do with the fishing folder error.
Fairly new to this sort of DIY, help would be much appreciated.
Add a comment
1 Answer
Most Helpful Answer
This is close to the first machine to use a flash drive:
MacBook Air 11" Late 2010 Solid-State Drive Replacement
So no hard drive. If you have a bootable external USB drive, plug it in, boot up holding gown the Option key, select the external drive. Now run Disk Utilities on the internal drive.
Score 2
Add a comment
Add your answer
Elkan Weilert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 115
