Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
wifi stopped working before dropping in fryer at work
my wifi went out suddenly about 4 months ago then a month later i dropped my iphone in a fryer at work. it still works but wanted to know is this something worth trying to clean it out as well as getting the wifi back working...i only use it for business, apps and music. no phone service
Score -1
Add a comment
1 Answer
Chosen Solution
as oil is quite thick it may not have travelled too far into the phone but whatever did travel will be a congealed mess.. i'd follow this guide for general advice but it seems you've been quite lucky really! if the phone service worked before the deep frying incident then I'd concentrate on the dock connector of the phone especially the USB connection part. This may resurrect your phone but if not then replace that part or just the antenna/USB section and you may find that wifi is restored too. Wifi antenna is connector 5 (i always get this number wrong but it's the little round pin connection on the top left of the motherboard) it may have dislodged after a fall etc, the antenna itself is pretty well protected so difficult to damage. If that doesn't help and you say you have no phone service is an imei no. displayed in the settings? if not and a clean and restore doesn't sort that out it may be the chip is damaged.
I'd imagine you may also have to spend a fair amount of your cleaning in the headphone jack and your sim slot...
let us know how you get on but if it's currently working as is then there's a good chance you can get full function back.
Score 3
Add a comment
Add your answer
Greg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 860
