Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Water Damage = battery + Wifi problems
So i Had a water damaged iphone, wouldnt restore and was messing up , so i replaced the battery. Now its all fine except: The wifi is greyed out and says no wifi. And When the phone turns on it says this accessory is not supported. What should i do, and if i should clean the logic board what should i clean it with and where should i clean it from.?
Score -1
2 Comments
Check on here Electronics Water Damage gives you a little bit more info. Good Luck
by
Ok Il give it a try. however a new problem has popped up:every time i click the home button or powerbutton it takes a screenshot?? the problem is fixed by restore it if i hold them together it starts again!
by
Add a comment
1 Answer
Chosen Solution
The "This accessory is not supported" warning is often due to shorting at the dock pins. Use isopropyll alcohol and clean very well the dock port, especially the pins which are on top of the dock mid rib. Be firm but do not break anything. A minute or two of cleaning will often cure this warning and problem. If one cleaning does not work, clean the port again.
Score 2
Add a comment
Add your answer
ubaid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,163
