Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Vertical lines on screen
I was trying to set some adhesive on the screen to keep it in place (as the pentalobe screw sockets snapped off), and I followed the guide which said to heat up the phone with a hair dryer until it was too hot to touch. I then turned on the phone and got a temperature warning. After that, the screen went all pixellated, and had vertical lines going down across it with a bluish tint to all colour on the display. I tried a good known screen, and that was fine. Is there any way to fix this, or do I have to replace the screen?
Add a comment
1 Answer
Chosen Solution
Sounds like you may have cooked the display or somehow damaged the ribbon cable, maybe with too much heat. Would suggest the only option is to replace the screen. I am sure you have tried re-seating the screen cables?
Score 1
Add a comment
Add your answer
Albert Einstein will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 216
