The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Mac battery draining rapidly after updating to MacOS High Sierra
Like the title says, I’ve noticed my battery draining rather quickly after updating to MacOS High Sierra. I’ve checked my battery’s status and it says it’s normal so I’m not quite sure what the problem is.
Any help would be greatly appreciated, thanks
Update (04/16/2019)
My battery is dead. I need to replace the battery on my MacOS High Sierra
Add a comment
Most Helpful Answer
Let’s take a closer look at it with a better tool. Please download, install, run and post your results using Coconut Battery. https://www.coconut-flavour.com/coconutb...
Score 3
2 Comments:
I have coconut battery. It claims the battery is good and still holds 91.6% of the design capacity
by
Can you post a snapshot of the main window with the MagSafe plugged in and a second image with it disconnected so we can see things. Here's how to post them Adding images to an existing question
by
Add a comment
Try and open Activity monitor, you find it in the Utility folder inside Applications folder. Launch it and from “view” in menu bar flag show all processes. Let it run and keep an eye out every now and then to see if any strange process is running continuosly or got stuck somehow. It might happen and that’s the right tool to examine what’s going on under the hood if battery is in good shape.
Score 2
Add a comment
Have you tried a SMC, PRAM/NVRAM reset? If not, perform those resets and see if it solves your problem.
How to reset the SMC, PRAM and NVRAM on a Mac Laptop
Score 1
Add a comment
Add your answer
Rusty Shackleford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 716
