Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
do I need to be grounded when replacing the back cover?
i have to replace my white backing cover for my 3gs. i was wondering if when doing so i need to be grounded so i dont destroy the phone, especially as i am dealing with the memory and mother board unit.
Score -1
Add a comment
1 Answer
Chosen Solution
Short answer: no.
Long(er) answer: This is mainly just an issue with desktop computers, when you have the tower opened and if you become charged (do not work on a carpet!) and you touch a PCI port they commonly get fried. Still, I don't wear a grounding strap when working on computers or other electronics, and mainly just use common sense. Just swapping out the rear panel you do NOT need to wear a grounding strap.
3 Comments:
though just remember you're liable for any and all damage you incur whilst performing your own repair.
by
I never wear a grounding strap.... Just make sure you "slide to power off " before removing LCD or it will blow...
by
Also, if you're uber-paranoid you can work on an antistatic sheet (just cut open an antistatic bag)
by
Add a comment
Add your answer
josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 653
