Why is my dryer spinning and sounding as if its drying but not
Why is my dryer spinning and sounding as if its drying but not it's a Russell Hobbs wd861400b
That number did not bring back any results on your machine. Is it gas or electric?
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 147
