USB port (left side) not working
The USB port near the upper left side no longer works, (PowerBook G4 Aluminum 17" 1.67 GHz). Can this be replaced relatively easy or does it involve solder and the logic board?
(Currently running OS 10.5.8)
Add a comment
Chosen Solution
That USB port is located on the DC-In board. You may be able to repair it by checking the cables connecting the motherboard to the DC-in board, or replacing the DC-in board. It is most likely not related to the logic board, or software.
Score 1
Comments:
Hey, thanks. Guess I'll pull it apart as if I'm working on the DC-in board and see if I can see anything not connected or loose. The DC does work, though.
by
Add a comment
Most Helpful Answer
Steve, now this comes from an absolute beginner on this, but the info I got out of the service manual is this:
A USB port is not recognizing devices
1. Completely shut down, then press the power button to start the computer.
2. Use Software Update system preferences to verify that the latest software is installed.
3. For USB, test ports with an Apple keyboard or mouse. If the left port is not recognized check the DC-in flex cable’s condition and connection. If the right port is not recognized check the right USB flex cable’s condition and connection.
4. If the USB flex cables are fine, replace the DC-in board for the left USB port or the backup battery board for the right port.
5. Use Apple System Profiler to verify that the computer is recognizing the bus. If not replace the logic board.
now I am certain that the Apple experts are going to get this answered better for you.
Score 3
Comments:
Thanks. I'm wondering now if it's just a matter of changing the PREM board that the USB port shares?
by
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,562
