Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Recently replaced Digitizer Issue
I recently replaced the digitizer (iFixit part), it seemed to be OK but after a few minutes it starts to type on it's own or if you attempt to swipe to the next page it will swipe back. I have taken it apart and everything looks good. Is it possible it's a bad digitizer?
Add a comment
Chosen Solution
It’s possibly a digitizer issue as the iPad mini is notorious for those kinds of issues. iFixit mini replacement parts are quite good quality however so as Lee suggests, contact support to see what they can do for you. The iPad mini has a few gotchas as far as the digitizer goes, @jessabethany did a great write-up several years ago and it still applies today.
Score 3
Add a comment
Head on over to iFixit support/warranty dept! They stand behind their stuff.
Score 2
Add a comment
You need to locate two foam ridges on both sides of the home button on the housing chassis, they are adhered onto a tape that is holding the LCD, you can either pull off the foam ridges or scrape them off.
The foam ridges often interfere with touch functionality (especially when install an aftermarket digitizer)
Score 1
Add a comment
Add your answer
Jeff Poulin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 170
