Rear brake shoes replacement?
After replacing the rear brake shoes the drum will not g back on. What can I do to fix this problem?
Menu
Your Settings
Rep: 1
Make sure that you adjusted the brakes all the way inward, it may be that your brake shoes are still extended and therefore bigger than the inside diameter of your brake drum. I attached 2 pages from the manual and that should help to determine what to do. good Luck.
Comments:
+ I had the same thought but deferred to someone more knowledgable on the subject
by mayer
Thank you Sir. Luckily rear drums really have not changed a lot, just the automatic adjusters are a bit of a pain at times.
by oldturkey03
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,298
