Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Boot loop caused by broken proximity thing?
Hello
I recently replaced my iPhone 6 screen.
During replacement, I broke my proximity meter thing.
The phone powered up fine, everything was working except for the proximity thing (when I made calls and held the phone up to my face, the screen didn’t turn off like it usually did).
The battery eventually died, and when I tried turning the phone back on, it got stuck in a boot loop. The apple logo seemed to flicker in brightness and sometimes I would get a red screen flash.
Other posts on here suggest disconnecting the cable and then trying to boot the phone up.
I did that, but the phone is still stuck in a boot loop with a red screen flashing sometimes. I also tried disconnecting everything but the home button and the screen itself. Still no luck.
Will installing a new proximity meter flex thing fix my phone?
Add a comment
1 Answer
Replace the proximity sensor cable. Then do a full restore via iTunes. It’s a hardware issue that caused a software glitch. Also try using the lcd shield from your old screen if you’re not already as aftermarket ones cause problems.
Add a comment
Add your answer
Brink Laubscher will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 36
All Time: 267
