The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
140 Questions View all
MacBook Air won’t turn on, freezing, crashing, spinning rainbows
MacBook Air purchased early 2015 won’t turn on,
I get a black screen with the Apple logo and a loading strip which doesn’t load. There is no water damage to the device but the hard drive is full.
Currently need the contents for Uni assessments. Have tried power cycling, SMC? Reset, holding shift, control and alt with the power key, holding command, power and the letters R and P, and holding shift and power which gives me a nearly full loading strip but unfortunately freezes right before success - so frustrating.
I have no tools to open things and I’m hoping to get it repaired before Tuesday (today is Saturday), any ideas welcomed.
TIA MShell
Add a comment
Chosen Solution
Do you have access to a second Mac which you can interconnect your system to using Target Disk Mode?
How to use target disk mode to move files to another computer
If you can you should be able to gain access to the files, At least save your stuff. Then reformat the drive and re-install the OS. You should be able to recover your drive.
1 Comment:
Thank you so much
by
Add a comment
The solid state drive has failed. Will need to replace and reinstall Mac OS
Add a comment
Add your answer
SD Card will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 122
