The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
p8lite doesn't turn off
Hi every one i’ve got a water damaged huawei p8 lite a followed various guides to repair it ,i teard it down cleaned it with isopropyl alcohol once i reassbled it i’ve put it on a charge cycle and apparently i did charge on full since the led gradually became green later i tried to turn it on but nothing happend except for the green light blinking so even without the charger plugged, so later i decided to turn it off to check if i could do something for the display but every time i try to press the power button for a hard shutdown the led shuts off but after a few it starts againg to blink.
ps: if i connect it to a pc it get’s recognized and i can see some folders called with the model name of the phone which is ALE-L21 the other one called Hi-suite
does any one knows how to move on?
Thanks
1 Comment:
I have this problem too. My can only restart. Every night im trying to shut it down, but it doesn t work. I think that s unrecoverable at that point. Also im searching how I can root it so I can use an app to shut it down.
by
Add a comment
There should be a problem with your screen. Did you clean the device by hand with alcohol? You should use a device called phone cleaner that uses ultrasonic sound to clean the motherboard.
1 Comment:
If your screen is the problem, it should be replaced
by
Add a comment
Power button damage by water clean it or replace it
Add a comment
Add your answer
frax119 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 606
