iPhone 5 does not charge/charges poorly while using
hi, i got an iPhone 5 with a little problem. if i plug it in the charger, it charges normallyi. f i leave the phone in standby, it takes about 2 hours to fully charge. normal
but if i use it while charging, sometimes it charger 2 to 5 % and then stops until you let it sit for 3 minutes and the same thing happens. it just doesn’t charge when you use it.
the battery has already been replaced. today i used another new battery and charging port and the same thing happens. here is a picture of the phone after i tested the new battery and charging port.
as you can see, absolutely clean on the interior. no water damage.
i have heard things about a 9 pin switch MOSFET and the NXPÂ 1608A1 host controller IC. being faulty. but i can run the entire battery flat and still charge it no problem. nor does it auto turn on when connecting the battery or drain/heat up unusually. so i doubt it is faulty. but i dont know.
does anybody have had a similar issue, and does anyone know a fix for this?
thanks in advance
