Repair guides and disassembly information for PC laptops of all shapes, sizes, and colors.
My BIOS setting error
I have tried hard to open my bios setting but any button don't work in my Samsung notebook laptop.
1 Comment
@kshetry
what model is your Samsung and what happens when you try? what exactly have you tried?
by
Add a comment
Chosen Solution
The timing to get to the BIOS is so slim it takes multiple attempts for many people. In most cases, I’ve found it’s a lack of knowing which key it is and not knowing which keys are commonly shared with the brand and in some cases, multiple OEM’s.
Figure out which key your Samsung uses and then start pressing it before it boots to get in without getting the timing wrong. Samsung isn’t as common, so there’s inherently less available information.
Windows 8.x screwed this up further for many. The timing available has been further reduced by the use of Secure Boot. On anything remotely modern, know the key by memory and jam it as soon as you turn the laptop on or you may miss the available window left.
Anyway, there are three common BIOS key configurations for Samsung. You either have to press F2, F10 or F10+power button to access the BIOS. Hopefully this information helps.
Score 1
Add a comment
Generally if your keys are damaged or dirty you may face such error as to enter boot menu you need to press esc,f1,f2 or delete button most of the time first shut down laptop and remove the battery and now dismantle the key used to enter bios and clean it with brush and refix it and try to enter bios after switching it on
Add a comment
Add your answer
Diwash kc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 89
