Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Can I replace my airport card?
I received from a customer a MacBook Pro mid 2014
She needed a new charger (the Apple Store told them it was the logic board, then she send it to 2 repair shops, where some of them give a piece (I didn’t know which one because I found the issue)
So when I booted up and asked her to put her password, it turned on! But the WiFi said there was no hardware installed (i assume it was the airport card)
Then I opened and there’s the Airport card, the piece that they took was the right speaker!
Can I buy another airport card or has the same issue like the iPhones with touch ID and need to use the exact airport card?
Score 1
Add a comment
1 Answer
Most Helpful Answer
To start with you can switch out the Airport board but I don’t think thats your issue.
More often the I/O Board cable has issues. I would try replacing it first. Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Retina Display Mid 2014 I/O Board Replacement Follow the steps till Step6 then jump down to step17 & 18. Here’s the part you’ll need: MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable.
If that doesn’t fix it here’s the IFIXIT guide to replace the AirPort board: MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement and heres the needed part: MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board Image
Product
$49.99
MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable Image
Product
$9.99
MacBook Pro 13" Retina Display Mid 2014 AirPort Board Image
Guide
Difficulty:
Moderate
30 minutes
MacBook Pro 13" Retina Display Mid 2014 I/O Board Image
Guide
Difficulty:
Moderate
45 minutes - 2 hours
Score 1
1 Comment:
actually you're right i notice the I/O board cable is not detecting anything not the USB port and HDMI, i might need to replace it, im gonna check how expensive is the cable
by
Add a comment
Add your answer
armandomh91 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 738
