Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 Questions View all
I have dryer GE but shut off when open door I feel the clothes humidi.
My dryer GE shut off when open door whitout finish cycle then close and start again and working litle and stop. I tested all thermostats and thermister theirs work done. I cleaned the lint ducts. The motor is clean and work good the voltage is fine. Which isThe trouble? Someone can help me? The model is DCVH660EHOWW.
Add a comment
1 Answer
Most Helpful Answer
Most Frequent Causes for Dryer takes too long
Cause 1
Air Flow Problem
If the vent is clogged or partially clogged, it will restrict the airflow through the dryer, substantially increasing the drying time. To ensure proper dryer performance, you should clean your dryer’s venting system at least once per year.
Cause 2
Blower Wheel
The blower wheel works with the drive motor to draw air into the dryer drum. Clumps of lint, socks, and small articles of clothing can escape the lint filter and get caught in the blower wheel. In addition, the blower wheel sleeve can wear out, allowing the blower wheel to wobble on the motor shaft. If the blower wheel is obstructed or defective, it may take too long to dry clothes. To determine if the blower wheel is working properly, remove the dryer vent and assess the strength of the air flow. If the air flow is weak, check the blower wheel for obstructions. If no obstructions are present, try rotating the blower wheel by hand. If the blower wheel wobbles as it turns, replace it.
Cause 3
Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve to allow gas to flow into the burner assembly. Sometimes, a solenoid can fail several minutes into the drying cycle, causing the dryer to take a long time to dry the clothes. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Score 2
Add a comment
Add your answer
joenjimenez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 74
