Red Screen Boot Loop
I have a iPhone 5s that is stuck in boot loop and goes onto a red screen then starts the loop again, how can i fix it? Thanks!
From my experience it’s either a bad front camera cable, Tristar chip (Charging chip that would need to be replaced via micro-soldering / board level repair) or at worst the NAND flash memory chip needing reprogramming and/or replacement.
Try unplugging the front camera cable then power it on again and see how that goes.
Thanks, i tried disconnecting the cable and it still happens, going by what you said i belive it will be a mothet board issue!
It is a board level issue like iphone 6 touch desaese
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,292
