Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Questions View all
Why does my ip 7 plus blinking 30 times when turning on
i am using this fine but why it’s goes turned off when sleep and whenever i listening songs it restarts and blink 30 times at apple logo and after that start but taking 4 minute in starting ,who can help me
Add a comment
Chosen Solution
The iPhone 7 series of devices have proven to be very unreliable, suffering from flex-based issues similar to the iPhone 6 Plus (Touch Disease). On the iPhone 7, the fault line runs along the top of the SIM card reader and affects mainly the Audio IC.
If you are seeing symptoms like those below, then this could be your problem:
  1. Voice Memos app / Loudspeaker on call - greyed out
  2. Siri doesn’t hear you / Caller can’t hear you
  3. Most other Audio related issues that aren’t solved by modular replacements
  4. Long boot times (3-5 minutes)
  5. iTunes detects the phone but stuck on the Apple Logo
This requires a micro-soldering repair and is not DIY.
Score 2
1 Comment:
i said , this is working as nothing any problem hv on bt why it's gone turned off when sleep,and it restarts when doing multiple when listening songs.....is this the battery prblm...
by
Add a comment
iPhone 7 series have most common issues that the Cpu have so badly heated.
Such Problems have mostly appear on forcely droped down devices.
I think like iPhone 6plus touch issues is common on 7 series behind Audio codec fault also have the fault of CPU.
Check while on blinking the CPU was mostly overheat or not.
1 Comment:
cpu heats after 30 times blinks at apple logo when it’s straightly without blinking turning on,i can’t put hand on, bt taking 4 minutes in turning! {1.is there any cpu shorting,? {2.or battery dead?
by
Add a comment
Add your answer
Prince Patil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 104
