Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
S7 won't boot: fixed blue LED and blinking green LED
Hi, my S7 had some battery related problem, and in the past some times failed to recognise the real battery level.
Now I have substituted my old battery with a new one and I have the problem explained in the title. When I push the "power on" button, the S7 vibrates and a fixed blue LED + a blinking green LED show up for some seconds, then "menu" and "return" buttons light up and finally all lights disappear and the screen remains black.
The combination "Power button + volume down" gives the same result, and the combination "Power button + home + volume up" gives no result.
If I connect it to a power cord, after some seconds a fixed red LED shows up, then in some minutes it becomes green. Nothing appears on screen and pushing *any* button result in a freeze from which I can exit only disconnecting the battery, during this freeze the phone heats up.
I think the smartphone is failing again in the measuring of the battery level, since it is behaving like the battery is empty. Any idea about how to solve this?
1 Comment
bro, did fix your phone? my S7 undergoing a same problem >.<
by
Add a comment
1 Answer
Most Helpful Answer
when you get to ‘and finally all lights disappear and the screen remains black. ‘ do the menu and return LEDs light up when you press the lock button?
Sounds like either screen not plugged in properly or got damaged when opening up the phone.
Score 2
1 Comment:
Thanks for the answer.
I have noticed that some time the smartphone acts like the screen is disconnected: it also rings if I dial my number from another phone.
But the connector is intact and well secured on its socket... Moreover, it still does not acts properly when connected to the power cord: the red led lights up after too many seconds, and in some cases the smartphone also froze with a fixed blue led.
by
Add a comment
Add your answer
Alessandro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,067
