Washer Beeps when power button is held, but does not power on
Hello,
I have a kenmore elite washer 796 41073310. When you press the power button breifly nothing happens. However, if you press and hold the power button. There is a beep and the LED display along with the LED light in the washer compartment, briefly light up.
This will continue for as long as you press and hold the power button.
This problem has been intermitant for the last month or so. If we let it sit, it will eventually work for a load or 2. Then stop again.
Hello Everyone, I have a Kenmore Elite Washer Model Number 796 41073310.
When you press the power button briefly nothing happens. However, if you press and hold the power button. There is a beep and the LED display along with the LED light in the washer compartment, briefly light up. This will continue for as long as you press and hold the power button. This problem has been intermittent for the last month or so. If we let it sit, it will eventually work for a load or 2. Then stop again. Here is a video of what is happening.
Is there a diagnostic mode for this?
2 Comments
Rich Ledvina all Kenmore 796 models are actually made by LG, so let's see what we find. You have downloaded the SM from the bottom of this page Kenmore Elite HE3 Washing Machine and tried to see if the diagnsotics works for your machine?
by oldturkey03
I have kenmore elite top load and it is touch screen. 2 of the touch screen buttons does not work and does the same as you described.
by Katherin Terry
