Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Make sure iPhone has Touch IC problem
I have an older iPhone 6. The frame of the phone has been bent and touch function sometimes works. I am not sure if it is a Touch IC problem as there is no grey bar at the top of the screen. The display does not flicker and it is just the touch that stops working. Also, whenever I apply pressure to the touch ic area, the touch starts glitching out. I have tried 2 working screens on it with the same result. I just want to make sure that it is a touch ic problem. Any thoughts?
Add a comment
1 Answer
Chosen Solution
Yep, you are right it's a touch IC issue, actually a symptom of it also includes ghost touch as you have found out.
These are usually the two most common failure modes of touch IC:
- Grey bar, intermittent touch functionality (completely stops working)
or
- No grey bar, intermittent touch and ghost touching sometimes.
Score 2
Add a comment
Add your answer
Blui will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 109
