MacBook not recognizing battery
My charger light stays green, and my computer goes out when I unplug the charger.
Here’s how to replace it:
MacBook Pro 15" Unibody Early 2011 Battery Replacement
I would first download and run Coconut Battery to see if you can get any better information on it. https://www.coconut-flavour.com/coconutb...
UPDATE
Try resetting the SMC
Connect the power adapter to the Mac. On the MacBook / Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time. Release all keys and the power button at the same time – the little light on the MagSafe adapter may change colors briefly to indicate the SMC has reset.
That failing zap the PRAM
Shut down your machine. Yes, all the way down, not sleep or logging out.
Press the power button and then press command-option-p-r. ...
Hold those keys down until your Mac reboots again and you here the startup chime.
Let go of the keys and let your Mac reboot normally.
I have replaced the battery twice, with Ifixit battery.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 26
