iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
RED X apple support/iPod?
I have over 3000 songs and over 30 vid/12 movies. Never had a problem with my ipod. Until one day on a fully charged battery while in the middle of a song I changed the song and no sound came out, I changed song again and again no sound. I then hit Menu, playlist to choose a song and all of a sudden a RED X with www.apple.com/support/ipod.
I then went online and followed instructions:
1.Disconnect iPod from your computer.
2.Manually put iPod into Disk Mode as explained in support document 93651.
3.Open the latest version of iTunes and connect iPod.
4.Restore iPod as explained in support document 60983.
However when I was able to get through #2...I followed instructions and then connected ipod back into computer.
Computer then recognized the ipod by pop up window stating "itunes needs to prepare you ipod for recovery, leave your ipod connected"
I do and run the recovery....then it resets the ipod to the APPLE sign and AGAIN shows the RED X and goes no further. PLEASE SOMEONE HELP!! This is my lifeline and need it! :)
Also I did try the whole Disk Management via right clicking on Computer management.
Score 1
Add a comment
1 Answer
Chosen Solution
Finish what you started:
Restore iPod from Disk Mode
1. Disconnect iPod from your computer.
2. Manually put iPod into Disk Mode as explained in support document 93651.
3. Open the latest version of iTunes and connect iPod.
4. Restore iPod as explained in support document 60983.
Doc 60983
How to restore iPod
1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
2. Download and install the latest version of iTunes if you do not already have it installed.
3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
4. After a few moments, your iPod will appear in the Source panel in iTunes.
5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Score 1
1 Comment:
+ you go mayer...very complete ;-)
by
Add a comment
Add your answer
Marcella will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 4,243
