Spin Cycle Does Not Work
Washing machine does not complete the spin cycle. Looking for a trouble-shoot solution (if any) before we call in the heavy artillery.
Unable to locate the manual for the machine. Many thanks.
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 54
All Time: 731
1 Comment
George Vourlojianis what is the complete model number for your washer
by oldturkey03
