Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
iPhone missing cable connection
does anyone know what dismissing cable may be ?
I am starting to feel that this has to do something with sim service because my phone says always no service or it is searching for ever
Under the battery connector)
Score 1
Add a comment
Chosen Solution
After you have eliminated antennae or network locks as the possible culprit, searching issues on the iPhone 6 are usually related to the baseband IC. The baseband IC is very sensitive, just like the Touch IC's on the 6 Plus; it also suffers from poor quality traces and pads.
Go to your phone’s dialing keypad and dial *#06#. You should see the IMEI displayed.
If the IMEI is not displayed, the Baseband IC has to be reballed and two small copper traces (U1/V1) have to be rebuilt and solidified. This is commonly referred to as the “long jumper” solution. You can check out this answer (Service is "Searching" indefinitely) (by @teetopp) as it summarizes the issue really well.
There is a long jumper solution being tried out by Chris Long (and others). Chris posted several videos and you can start with this one.
Score 2
Add a comment
To answer the direct question, the cable near the battery connector is for your data connection. It must be plugged in or you will get no service... but if it is plugged in, then as @refectio mentioned, it will need the Baseband repair completed to restore this common issue
Score 1
Add a comment
Add your answer
Nenadbrateu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 120
