Repair guides and support for top and front loading Whirlpool brand washers.
Washer won't spin or drain, just buzzes
I just replaced the clutch on my top loading Whirlpool washer about a month ago, and it was working great as of yesterday. Then today, my wife put a load in today; the drum filled up but won't agitate or spin. When I put my ear to it, I can hear it buzzing, but nothing is happening. Any advice is welcome!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 2
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Score 2
Add a comment
Add your answer
Steve Morgan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 30
All Time: 22,694
