Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5s leftover part after battery replacement
I’m used to having leftover parts after an auto repair, but not so much for iPhones. I followed the steps to replace the battery on my wife’s 5s, and everything went smoothly until I was about to reattach the battery connector when I noticed a leftover piece at the top left of the chassis. I didn’t remove it, and I can’t find in an exploded parts diagram. I put the phone back together, and so far it seems to work fine. Can someone educate me about this part and the necessity of putting it back? If so, where does it go?
Add a comment
1 Answer
Chosen Solution
It helps keeping in place the home button flex cable. If you look close enough you will see where the cable connects there's room where to fit it..flat part will be on top. It has to be pressed down gently until it clicks in place.
Score 2
Add a comment
Add your answer
AR will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 46
