MacBook battery undetected and don't charge
Hi All ,
A broke college student with a cry for help . Situation in short is as below.
MacBook Pro battery had to be changed due to "service Battery" indicator.
Got a new battery and tried to change it by myself .
Accidentally screw driver touched the battery connector (its metal connectors which connects to the mother board ) while its still plugged in and saw a tiny spark . and now
Macbook wont identify either of the batteries and its indicated as ( x )
Magsafe is always green and MacBook starts on its own .
I did my research and checked the board for burnt resistors but couldn't find any .
i6259/u7000 has no damage marks from out and I don't know how to check it with the multimeter (please advise . instruct )
I checked few resistors around with multimeter (200k ohm) and they given me a value of 0.21 I randomly checked few resistors which is around the U7000 chip .
I'm broke and even more broke with the battery purchase. I don't have money to get this fixed as at now, so I would highly appreciate any sort of comments on this.
Yeah, CoconutBattery does not detect any batteries and SMC is reset was done multiple times and chip seems to be fine as my fans run ok, and also no overheat issue. Battery indicator lights also does not work.
I highly appreciate resistors to be cheeked advise with them marked on a pic
2 Comments
With the battery removed, are you able to get the system to run with the MagSafe adapter plugged in? If that works plug your old battery in to see what it does.
by Dan
Dan , Thank you for the reply . yes the Mac can run without the battery plugged in and I have already checked both the batteries and no luck .
by Thilina Gdna
