Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Stuck in Bootloop before and after replacing battery
With my 6s+ the battery went from 90% to 1% and restarted itself over and over, and then wouldn't charge. I thought the battery was to blame so I replaced it. It worked good for a day and then its back to 1% and restarting. Now, its stuck in a boot loop were it will go between quickly flashing the backlight and flashing apple logo. Any ideas? Ive tried to restore but it doesn't stay on long enough.
Also, when I first opened the phone 6 months after buying it on eBay, the battery connector cover was missing. I read online it could be the battery sensor. Any ideas?
Add a comment
Chosen Solution
Try applying some pressure down on the connector while the phone turns on. If it works fine then you just need the metal bracket. If not then you might be missing some components near the battery connector which are commonly knocked off when preforming a battery replacement.
Score 1
1 Comment:
Thanks! Im going to have it replaced sometime this week.
by
Add a comment
Most Helpful Answer
I think you need the battery connector cover, the battery ribbon cable plug may have a loose connection to the battery connector on the board requiring that metal cover that goes over the battery connector and charging port connector.
iFixit sells the battery connector bracket here:
iPhone 6s Plus Battery Connector Bracket
Here is a guide in case you need it:
iPhone 6s Plus Battery Replacement
Fix a loose connection causing charging and connectivity problems by replacing a bent or missing metal bracket securing the battery connector and lightning port assembly connector to the logic board. This part is compatible with an iPhone 6s Plus. Image
Product
$6.99
Score 2
2 Comments:
Would this really solve my problem? Ive snapped both connects in tight and it still wont work.
by
If you have tried turning it on while applying pressure to the connection then it won't work.
by
Add a comment
Add your answer
Michael N will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 256
