The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
trackpad wont click down at all
when i say it wont click, i mean it is tap reseponsive, it just wont click down, its been happening for about a year now and i need help. it will not click down as in i cannot drag photos or files without the help of a mouse.
Score 1
Add a comment
Chosen Solution
Your model uses a touchpad which unlike the older trackpad does not have a mechanical clip plate. There is no means of adjustment only replacement. Here’s the IFIXIT guide you’ll need to follow: MacBook Air 11" Early 2015 Trackpad Replacement and here’s the needed part: MacBook Air 11" (Mid 2013-Early 2015) Trackpad
Replace a trackpad compatible with the Mid 2013 to Early 2015 MacBook Air 11" model A1465 laptop. Part #923-0429. Image
Product
$57.99
Score 1
Add a comment
Actually there is an adjustment screw that you could try before replacing the trackpad, if you have the laptop open, it is at the bottom center, right below the trackpad, you can see it in the video thumbnail. It is a T5 screw. Try that first before replacing the trackpad.
1 Comment:
If the trackpad does not click, how would I use the screw to adjust or fix that? Thank you.
by
Add a comment
Add your answer
Logan Emtman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,042
