Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
earspeaker dosent work (i think I shorted it out)
i took my iphone apart to replace a faulty vibrator motor... after i replaced it i was reassembling it and when i wanted to connect the screen with the nr. 3 connector i accidentally touched the pins with a screwdriver, and i saw a small spark ... i noticed a very faint smell of (burning electronics)... i managed to re assemble the phone.. i turned it on, seemed to work fine.. i tested the touch sensor ,home button, proximity sensor, ambient light sensor, and they all worked but when i got to testing the earphone it didn't work...
i think i shorted something out... but i don`t know if it is the speaker itself or something on the motherboard...
if i order a replacement earspeaker will it resolve my problem???
any ideas?
Score -1
Add a comment
Chosen Solution
Sparks are not a good thing during a repair. If not the earspeaker, then Flex Cable #3 would be the next part to try. If that is not it, then Logic Board.
The most fragile part in this complex of parts is the Flex Cable #3, then the #3 connector piece, then the Speaker itself. But with sparks flying who knows.
Good luck,
Brad
Score 1
9 Comments:
The ear speaker is just a simple magnet, there isnt anything to "short" out on that, I would check the #3 ribbon if you're having ear speaker issues. Does the proximity sensor work?
by
what is the purpose of the very very fine copper wire wound round the speaker then? I would have thought that this could easily be damaged by power surge..
by
The speaker is like a magnet. Sound is induced by electrical current to move the membrane, but there isnt anything to actually "short." Its like when you wrap a copper wire around a screwdriver and connect the leads to a battery. You basically create an electromagnet.
by
so looks like you are in agreement with what Brad stated..
by
If a current surge passed through a hair fine wire it wouldn't damage it? Prevent the electromagnet from receiving power?
by
Show 4 more comments
Add a comment
The speaker isn't damaged. It is the #3 ribbon cable. You can get one off ebay for $7 or less and make sure you search for US only. This cable is a little tricky to install because the metal clip that hold it in is quite sturdy. Bending it a little bit is okay, but make sure you bend it back. That is really the only thing I can think of that got damaged. I highly doubt it is your logic board. But I guess there is a small chance it could be. Hope that helps!
Add a comment
Add your answer
Ignat Robert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,496
