iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
Temporary repair v-sync cable?
So I opened up my late 2009 27" Imac to install a new hard drive got everything in good but when I went to plug the v-sync cable back in the metal leads on it would scrunch up. Is there anything I can use to temporarily get the leads to stick to the ribbon so I can get it plugged back in?
Score 1
Add a comment
Chosen Solution
It looks like you need Apple Part # 922-9161 if you have the 3.33 GHz machine. You can do a web search for that number or just go here and get it for $19.00: http://www.applecomponents.com/items/000...
Score 3
Add a comment
I used 2sec glue worked fine for me
Score 2
1 Comment:
can you explain exactly how you did this?
by
Add a comment
you didn't need buy a new v-sync cable ...
you can fix it your self with adhesive tape double sided !!!!
you need a cutter and scissors.....
if you need more help don't hesitate !
it's realy easy and FREE !!!
enjoy ;)
2 Comments:
simo, why not explain it on here. That way others with the same, or similar problem, can find the answer as well. It's about empowering each other
by
I agree with oldturkey03 and Diether Busch: I would like to know exactly how you did this. Pictures would be especially helpful.
by
Add a comment
Could you explain how it works with a taper?
Add a comment
Add your answer
nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 5,105
