Announced in October 1999.
iMac dv won't complete startup
After attempting to install updates i believe 10.2.4, it required a reboot but system just gets to the Apple logo screen and the timer wheel keeps spinning. I have left it in this state for hours never completes. I have tried all sorts of key start-up combinations: s, command-s, shift, cmd+shift+del+opt, v, spacebar, cmd+opt+o+f. never gets past apple logo.
i don't have OS disks. any ideas would be welcome.
thanks in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
If OSX is installed, restart the iMac while holding down Command S. When the text page appears,
Type: fsck -fy then press RETURN key (NB: there's a space between k and -).
You'll have to wait a little while the installed OS is scanned and repaired. When the repair is done you should read "The volume <<hard drive name >> appears to be OK" If you see "File system has been modified" retry the procedure (fsck -fy) until you see "The volume <<hard drive name >> appears to be OK" then type reboot and hit RETURN. The iMac should restart and boot a repaired system.
1 Comment:
I have tried multiple holding keys at power-on each combination for about 25-30 minutes each try until my fingers cramped. i actually put a weight on the shift key and let that go for a few hours. All with same result. Apple logo screen appears, hard drive crunches and the little wheel spins and never gets to text display or desktop. thanks for the suggestion. i may have to buy a copy of osx tiger or try a ubuntu boot disk and try repairing from within ubuntu.
by
Add a comment
Add your answer
ronf57 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 735
