Why can’t I hear my music from speaker and it says headphones are in
Says headphones are in but they aren’t
There may be debri in your headphone jack on the metal leads. If it’s not that then you might have a faulty part or a problem with your PCB board.
Yes this is the correct method of cleaning out debris, a lot of the time this the solution.
Advice for OP:
If you have cotton buds, take a bit of the cotton off then with the rest of the cotton bud dip it in 99% isopropyl alcohol then insert it in the headphone jack and rotate it a bit, that can clean up the contacts and the inside of the headphone jack.
But first I recommend cleaning it carefully with straight pointed tweezers and a flashlight to see clearly inside the jack.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 28
