Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Why can’t I hear my music from speaker and it says headphones are in
Says headphones are in but they aren’t
Add a comment
Most Helpful Answer
There may be debri in your headphone jack on the metal leads. If it’s not that then you might have a faulty part or a problem with your PCB board.
Score 1
1 Comment:
Yes this is the correct method of cleaning out debris, a lot of the time this the solution.
by
Add a comment
Advice for OP:
If you have cotton buds, take a bit of the cotton off then with the rest of the cotton bud dip it in 99% isopropyl alcohol then insert it in the headphone jack and rotate it a bit, that can clean up the contacts and the inside of the headphone jack.
But first I recommend cleaning it carefully with straight pointed tweezers and a flashlight to see clearly inside the jack.
Score 1
Add a comment
Add your answer
asteele40 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 27
