Cellular version of Apple's 2nd generation iPad Air. Model A1567.
87 Questions View all
My ipad screen getting wrong.
Can anyone explain what wrong with my screen? I tend to order a new screen and replace by myself but I'm not sure what the cause is? I’ll appreciate if anyone had the same problem with me and share your experiences for a precisely diagnostic! Thanks you so much!
Add a comment
Chosen Solution
I would tend to suspect a damaged screen. However as Nicky suggested, you should try to do a hard reset (Home & Power Button for 10 secs) of the device to see if that helps. If it doesn't then the next step is to try a replacement screen. Unfortunately, iPad Air 2 replacement screens are very expensive right now. You could bring it into a shop and ask them to see if the screen is the issue. They may charge you a diagnostic fee but that is less expensive than ordering a screen just to find out.
Score 4
1 Comment:
My Ipad Air 2 had the same problem. It would return to normal after a day of non use. It slowly got worse until the screen would freeze and go black. Given that new info, do you still suspect a bad screen, or is it more likely the logic board? Thanks in advance.
by
Add a comment
Did you try take a backup and reset the ipad ? i highly doubt this is a screen problem, more like a software problem, also it could be a defect homebutton in the meaning that it will work but if you click it it wil stay clicked giving you everything to see ( siri and so on )
Score 1
Add a comment
Add your answer
Khoi Nguyen will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 13
All Time: 1,018
