not spinning or rinse
The washer fills with water then immediately goes to spin, doesn’t spin, then empty’s water out
This can caused by a failing water inlet valve. If the machine is filling slowly, it can be timing out and going to the drain cycle. How long does it take to fill?
UPDATE
This can be several different things:
The lid switch is the most likely part to fail in this circumstance. However, this is only the most likely and there may be another part at fault. Here is a short list of ALL the parts in your top load washer that may have failed (and caused your particular problem) in alphabetical order…
Cycle Selector Switch – The cycle selector switch controls the speed of the motor and if it goes bad it can stop the motor from operating.
Drive Belt – If the belt falls off or becomes worn the transmission will not turn and the machine will not agitate. The machine will make a humming noise as the motor will be running.
Drive Motor – This motor turns the agitator and drum to wash your clothing. If it goes bad the machine will not agitate.
Lid Switch – The lid switch makes it so if the lid is opened, the machine will not run. A bad lid switch will make it so power cannot get to the drive motor.
Timer – The timer supplies power to turn the motor. If the timer is defective, the motor will not turn therefore no washer agitation.
Water Level Switch – The water level switch (aka Pressure Switch) controls the water level. If defective the motor may not receive power.
It takes about 10 mins to fill. The machine never washes the clothes. Fills then empty’s and drains. That it then it beeps like it’s done. We usually have to turn it to drain and spin to get out all the water
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,329
